Just got a 2009 LX150 with only 2.6k miles on it. Previous owner had a oil and filter change done at 2k. Looks and runs good. Except it wont start when cold with throttle in idle position. Needs a bit of twist of the throttle to get it going. And once it does, it will start fine on consequent warm starts with throttle at idle.
Idle is good and stable. Does not shut off or run erratic or anything.
Not knowing how old the gas in it was or how much use it had seen recently I have filled it up (1 gallon) with premium 91 octane gas and added the standard dose of seafoam to it.
What might be going on ? What can I check or do to have a quick smooth start at idle ?
Thanks!
