@stollerscoot avatar
1964 VBB
1964 VBB
Hey again,
I want to reach out to the community to ask for guidance on installing the gear and throttle washer sets for my VBB. Attached is a marked up image of the washers. Can someone please confirm for me:
Does the thicker washer goes on the gear handle, between the headset and handle?
Do the thin washer and curved washers go on the gear and throttle handles inside the headset? What order are they installed and which way does the tab point on the curved washer?
What is the large single washer used for? Is it for a different model Vespa?
Thanks for your help
Josh
Washers and handlebars
@chandlerman avatar
Innovator
186 Days Since Last Explosion
Innovator
@chandlerman avatar
Check out Scooterhelp's parts book, starting here:
1964 VBB
1964 VBB
Chandlerman,
Thanks. I've reviewed those diagrams again and again.
On the gear side is #60312, the fiber washer between the headset and handle?
Do #60566 and #60565 washers fit on the handlebars inside the headset with the tab of # 60565 facing toward the pulley?
What does the large washer do?
@chandlerman avatar
Innovator
Innovator
@chandlerman avatar
I just went and checked. Lucky for you my VBB has the headlight out right now
On my VBB, it's (from inside-to-outside/grip):
- Throttle/Gear shift pulley
- Tabbed washer, tab facing in
- Wavy washer
- Fiber Washer
1964 VBB
1964 VBB
Right on Chandlerman...as I suspected. Thanks for the confirmation!!!
@chandlerman avatar
Innovator
Innovator
@chandlerman avatar
Glad I could help!
It's amazing how such a simple bit of information can be so hard to find sometimes.
1964 VBB
1964 VBB
Its just good to hear from someone more experienced since I've never done this before
@mr-blazer avatar
Primavera 150; SS180
@mr-blazer avatar
Note that both the shifter and throttle pulleys have holes to insert the wavy washer tab. The hole in the shifter pulley is on the "back".
@chandlerman avatar
Innovator
Innovator
@chandlerman avatar
I've never done it on a VBB yet, just my GL, which is a different headset/tube setup. I was able to wander out to the workshop and take a look, though.
1964 VBB
1964 VBB
thanks blazer. as I was dry fitting the pulleys and washers, I identified that the tab does fit into the hole on the back side of pulley
@zachyzach avatar
@zachyzach avatar
I know it's a couple years old thread, but I am wondering if Stoller or anyone else remembers exactly where the single larger washer goes in the VBB headset assembly? Is that part 60312 in the diagram that goes over the gear tube for friction with the L side of headset?
I actually can't find this bigger washer in my stash, despite having a few headsets taken apart, but I do have the other washers (tabbed, fiber, and also a single thin metal one that I could use, which is the same size and WILL fit over the gear tube).
Thanks!
1964 VBB
1964 VBB
Zach,
I'll take a look at my handlebars when I'm home and try to refresh my memory.
@zachyzach avatar
@zachyzach avatar
Stollerscoot wrote:
Zach,
Thanks. Update: I looked up the part on scooterwest's site eventually, and there's a description in this link below. Pity I don't have the part but I can find something to use. But yeah, link says this:
BRAND
Vintage Vespa Item
DESCRIPTION
N.O.S. Outer Washer for Shift Tube Pulley - Most Vintage Vespas
Washer for the shift tube. This washer gets mounted outside the headset and makes the shift tube rotate freely and correctly against the handlebars.
See the related items below for more similar washers.
0.5mm thick
29.5mm outer diameter
22.2mm inner diameter
Fits:
--Vespa VNB 125cc
--Vespa VBB 150cc
--Vespa VS2-VS5 GS150
--Vespa VSB GS160
https://www.scooterwest.com/thrust-washer-shift-tube-pulley-vintage-vespa-nos-060312.html
1964 VBB
1964 VBB
Also reach out to Scootermercato. Dave and Matt are incredibly helpful, and their prices are the most competitive around.
@zachyzach avatar
@zachyzach avatar
I am a big fan.
@chandlerman avatar
Innovator
Innovator
@chandlerman avatar
Just so I'm 100% clear...we're talking about the gear tube spacer and not one of the inside spacers/washers, right?
And I third Scooter Mercato. Call 'em up and they'll know the part and hook you up.
@zachyzach avatar
@zachyzach avatar
Correct.
Good idea. I have an order in the works anyway. Maybe they have an extra.
[ Time: 0.0153s ][ Queries: 4 (0.0080s) ][ live ][ 343 ][ ThingOne ]
