Hi guys,
After many many hours of confusion and admittedly too much money spent on parts that haven't fixed the bike, I thought I'd join here and ask if anyone knows the solution.
I have an 01 ET2 50cc that won't start. The electric start hasn't worked for a while now, and I've tried replacing the relay with no luck so I decided to just stick to kick-start.
This worked fine for about 18 months but now my bike won't start at all. It has a new exhaust, throttle, automatic choke, and I've made sure it's full of fuel and oil. I even tried a new carb but that led me nowhere so the original one is back on. I've taken the spark plug out and tested it and it seems to be fine with a good spark, gave it a clean and popped it back in. It's also had a new fuel tap and reed valve recently which previously worked fine.
So, after all this and hours of trying to kick-start the bike, it's not running and I've no clue why. I've even sucked on the vacuum to get plenty of fuel down into the float bowl with again, no luck.
I'd rather not have to sell the bike as it would be much cheaper to keep as I only need a bike for another few months now.
Any suggestions to fix are welcome! Thanks.
