Gts 300ie and vespa lx125 3v
Posts: 36 Location: lincoln, england |
Does anyone know the diameter of the stock exhaust. Tbe bit where the actual graphite bush goes?
![]() UTC
2021 Vespa GTS 300 Super HPE
Posts: 113 Location: Fort Pierce, Florida |
![]() 2021 Vespa GTS 300 Super HPE
andrew5343 wrote: Does anyone know the diameter of the stock exhaust. Tbe bit where the actual graphite bush goes? Note: To install a new bushing you pretty much have to use the expander tool scooterwest has > https://www.scooterwest.com/tool-exhaust-expander-toolex.html < to drop it in there, otherwise you'll have a difficult time. |
![]() UTC
2007 LX150 2015 GTS (running like a charm!) 2017 BV 350
Posts: 12382 Location: Fond du Lac, Wisconsin |
![]() 2007 LX150 2015 GTS (running like a charm!) 2017 BV 350
Pegasus Prime wrote: Note: To install a new bushing you pretty much have to use the expander tool scooterwest has > https://www.scooterwest.com/tool-exhaust-expander-toolex.html < to drop it in there, otherwise you'll have a difficult time. People have gotten by with prying the tabs back slightly as well...YMMV |
![]() UTC
GTS 300ie
Posts: 1685 Location: Sunshine Coast, Australia |
![]() UTC
andrew5343 wrote: Does anyone know the diameter of the stock exhaust. Tbe bit where the actual graphite bush goes? 2- Outside Diameter without Clamp 1.60 inch 3- Inside Diameter with Bushing 1.22 inch 4- Inside Diameter without Bushing 1.50 inch ![]() Outside Diameter with Clamp 1.70 inch
![]() Outside Diameter without Clamp 1.60 inch
![]() Inside Diameter with Bushing 1.22 inch
![]() Inside Diameter without Bushing 1.50 inch
Posts: 3766 Location: East Anglia, UK |
Pegasus Prime wrote: Another rider gave me their new stock exhaust from a 20 HPE after they upgraded so the next time I swing by the storage garage where I keep it, I have a micrometer and can measure the inside and outside if that works for you. Note: To install a new bushing you pretty much have to use the expander tool scooterwest has > https://www.scooterwest.com/tool-exhaust-expander-toolex.html < to drop it in there, otherwise you'll have a difficult time. |
