Sat Jul 03, 2021 4:43 am
GTS 250
GTS 250
Sat Jul 03, 2021 4:43 am linkquote
So I have bought my oil and my new red chilli Malossi filter for my GTS250. Today was going to be a simple oil drain/replace filter job.
But oh no!! It seems like I am now going to have to completely remove my PM Tuning exhaust pipe in order to do this!!
Bummer!!!
Sat Jul 03, 2021 4:52 am
Sat Jul 03, 2021 4:52 am linkquote
Remove the old filter with pliers. You don't care if you scratch or bend the old one. Replace with a filter with a hex nut on the end, like a HF-197.
Sat Jul 03, 2021 4:59 am
GTS 250
GTS 250
Sat Jul 03, 2021 4:59 am linkquote
Hi - the picture doesn't really do the issue justice. The oil drain bolt is snug up against the tail pipe, so I can't remove either it or the oil screen tube properly. Grrr.
Sat Jul 03, 2021 5:06 am
Sat Jul 03, 2021 5:06 am linkquote
I see. Maybe you can just loosen the exhaust enough to get the filter off. Good luck!
Sat Jul 03, 2021 5:51 am
73 & 74 Rally, 76 ET3, 80 P200, 06 PX150, 61 Ser 2, 65 Silver Special, 86 Elite 80, 2015 HD Road Glide Special, 2011 Ural Tourist
Sat Jul 03, 2021 5:51 am linkquote
Lame design but you gotta remove the exhaust on the LXs too.
Sat Jul 03, 2021 5:50 pm
Sat Jul 03, 2021 5:50 pm linkquote
Isn't the proximity of that hot exhaust doing your engine oil (and engine) no good at all?!
Sat Jul 03, 2021 7:38 pm
Sat Jul 03, 2021 7:38 pm linkquote
Do you mean if an aftermarket pipe is installed?
I almost always leave the (OEM) exhaust in place when I change oil on my LX. It's tight, but there's enough room.
Sat Jul 03, 2021 8:19 pm
Sat Jul 03, 2021 8:19 pm linkquote
They're all tight. I got sick of fighting the exhaust so they all come off now. Gives me more access for the gear oil change too.
O.S.- how could the exhaust piping cause harm to the engine oil/ engine? I'd seriously doubt any radiant heat from the piping could go through the air, into the oil filter and then break the oil down prematurely. How is the exhaust routed on your Liberty 150?
Sun Jul 04, 2021 4:04 am
Sun Jul 04, 2021 4:04 am linkquote
We Liberty owners do not have to remove the exhaust to change the oil or the filter.
  DoubleGood Vespa Design
[ Time: 0.0336s ][ Queries: 7 (0.0103s) ][ Debug on ][ 211 ][ Thing One ]
