Brendanok wrote:
My tilt lock does not operate when ignition is turned on. It may take 10 or 20 attempts. When it does operate it is fine. Can some one give me a few hints. Battery is fully charged. Could it be a regulator.
Hi,
Depending on the age of the scooter, if it is old, and everything else is ok (battery etc...) and you done the maintenance, then most properly it will be the switch, you need to get the a new switch.
What you can do, if you have someone else who has a similar scooter is change the switch from their scooter to yours and check if it works, it is nearly a 45 minute work (from start to finish) and not hard,
Good luck.
