So I was starting up the p200e and I was pulling the choke out to get it going. There was a bit of friction and I used too much muscle to pull it out more which caused it to come out all the way. I pushed it back but not sure if I disconnected anything. Basically need to know if I need to reconnect it to something or by pushing the choke leveler back in is ok and nothing to do.
1963 Vespa VBB, 1965 Allstate Cruisaire, 1974 Vespa Super, 1980 Vespa P200, 2003 Stella 2T, 2008 Steall 2T, 2022 Royal Alloy 150 GT
Posts: 383 Location: Kansas City |
If the choke lever separated from the scooter you will likely need to pull the tank to fix the issue.
Well I just checked again and from what I read it is hooked to some cable. The cable was still attached to the leveler. So I’m assuming I’m ok.
Moderibbit
Posts: 8891 Location: Atlanta, GA |
Just pop the carb box lid and see if
1) the cable is still attached 2) pull the choke knob in and out and you'll see if it is operating the carb lever http://vespamaintenance.com/fuel/carbrebuild/index.html Right-most arrow on 3rd pic |
Johnny Two Tone
Posts: 9059 Location: San Diego, CA |
Just to add on, when you do check the function you can actually look down a small hole from above and see the brass plunger move. It needs to close fully but opening can be less than all the way.
Thank you very much guys. I will take a look tomm when I have some time. Only thing that sucks for my situation is I live in a condo and I have to do this stuff in the garage. With this heat and humidity it’s a bitch. Oh and the annoying people who live there and see tools out and start freaking that I’m doing mechanic work there. Can’t wait to move into my own house.
Moderibbit
duorotte wrote: Only thing that sucks for my situation is I live in a condo and I have to do this stuff in the garage. With this heat and humidity it’s a bitch. Oh and the annoying people who live there and see tools out and start freaking that I’m doing mechanic work there. Can’t wait to move into my own house. |
duorotte wrote: Thank you very much guys. I will take a look tomm when I have some time. Only thing that sucks for my situation is I live in a condo and I have to do this stuff in the garage. With this heat and humidity it’s a bitch. Oh and the annoying people who live there and see tools out and start freaking that I’m doing mechanic work there. Can’t wait to move into my own house. Remove the two slotted cover screws. There's a wire noose-looking little thingy that connects to the choke. Sometimes they slip off. You can use that screwdriver to open the choke lever enough to slip that noose back on. |
Well all fixed. Had to pull the gas tank. The clips popped off which caused the choke lever to pull out and connected it back at the other end. First repair due to my gorilla strength disengaging the choke lol. Definitely helps with another pair of hands.
