Undo the four screws holding the top of the headset on. Then go down to the bottom of the fork and push (feed) the slack out of the speedometer cable. That separates the top of the headset.
Then get inside, undo the round ribbed speedometer cable nut and metal bracket, and bulb wire. The unit then pops right out
The ring is crimped over the bottom edge of the speedometer unit casing. Gently pry it up all around with a pick or small flathead screw driver until the ring, gasket, and glass come off. If the ring and glass are wasted, buy new parts.
