one pic shows that gps is so laggy that it gives very misleading results for acceleration.
why? 'cause I can only convince android to give me updates once per sec. look at the red vs green in the top part and you can see that the red (gps) doesn't start moving to almost 1sec after the bike speedo (green). "But the bike speedo is inaccurate" i hear you shout. yes but not here. what do I mean? I've calculated accurately enough that the speedo on *my* bike is 8% exaggerated so I reverse that (subtract approx 7.5% ) before graphing etc. how did I calculate this %? by comparing to the GPS when running at a steady speed in a straight line for several secs.
the other pic shows that I did get 3.1secs for 0-60 but am more consistent around 3.3-3.4. this graph is just for fun
when the belt and rollers were old (rollers had flat spots) was only getting around 3.7sec.
I don't have any good 0-100 data as it's so rare that I actually do this but I think it's approx 12 ish from the handful I have done
the fun you can have with data
notes:
* phone gps: pixel4a5g with android 11 but have also same results with other test phones. 1 per sec
* bike data: sampled at 10 per sec via bluetooth. should also work with other scoots with bluetooth such as the 75th GTS or Primavera Sport
* bike: 2019 Supertech APAC. has the snorkle style airbox not the classic gts airbox
* tires: pirelli diablo rosso at 29psi (rear) 27psi (front)
* bike mods: currently only Arrow exhaust
* temperatures: air intake 40-45C, weather 12C
* my weight: 67kg + bike gear
β οΈ Last edited by SteelBytes on UTC; edited 2 times
