I've been chasing a leak on a PX200e engine and am pretty sure it is coming from under the carb box. I have replaced the carb gaskets once already so today I took it apart again but this time I spent some extra time surfacing the carb box.
I also wanted a little tougher gasket so I decided to try my hand at cutting a new gasket for the seal between the carb filter box and engine case. It was a bit of a tedious process but in the end, I successfully scanned, scaled and cut a new gasket using my laser engraver/cutter.
I guess time will tell if my fix worked this time.
https://youtu.be/yn4pKVeQm-0 (Video of the laser doing it's thing)
