Finally after how many years there is an option now for GS 150. Bollag Motos in Switzerland has released a batch of aluminum cylinders for the Gran Sport. My GS has been parked waiting for motivation to replace a leaking clutch side main seal which has arrived.
Cylinder seems fairly straight forward with a new inlet manifold and exhaust manifold with a modern slip stub to accommodate modern day PX type exhausts with a swingarm bracket.
The crankshaft is a 60mm DRT with a PX type clutch side axle offering many options there.
Plan is to rebuild engine match case transfers new main bearings and seals. Going to need help setting up cylinder port timing.
12
