@jezibel_tires avatar
ET4
ET4
I know the topic of removing the EVAP has been beaten to death, so.. apologies, but I just want some validation that my current situation is indicative of a clogged EVAP.
First I will say, that the hose (C on image) on the evap system coming from the carb to the tee junction as seen in the image, is broken near the tee junction. so for all intends and purposes I have the hose removed from the carb currently, which I know is not the complete evap removal, but seems to be the test they suggest to see if problems are evap related.
As for the image, my evap system is difference, where I have two hose nipples on the manifold just like in LX150 Complete EVAP System Removal <--this write up
So basically what is happening, it struggles and stalls at red light, especially when it was hot. and at high speeds and accelerating it struggles, feels like someone is pulling a rope on me like the rpm flutters if that makes sense.
I am not oppose to removing the evap even though I don't understand fully the repercussions? Will it just make Leonardo Dicaprio upset? does the rollover valve save my fuel in an accident? I think the only thing I am concerned with is fuel emitting from it while parked, I park some places where vapours and leaks would not be appreciated.
And again, I am having these symptoms but are they are indicative of evap? considering I already have a broken 'C' line? my carb was cleaned a year or two ago (didnt need it)... so I somewhat can rule that out I guess...
@greasy125 avatar
@greasy125 avatar
Pull #3 and just tuck it in somewhere. No biggie. Don’t touch anything else…
*unless* you’ve got a cracked intake manifold OR one of the two coming off the intake is compromised.
The small one, you can trace it back, is vacuum for the fuel tap. Check it and your intake throughly for any kind of deterioration.
The big one is bullshit. You can pull it and cap it off, but if it looks fine don’t mess with it. It goes to a one way valve so no biggie there.
If you wind up replacing the intake, eliminate and cap it. And if you do the intake, do the fuel and vacuum lines.
hth
@cosmos avatar
2009 LX 150, 2024 GTS Super
@cosmos avatar
You might spray some carburetor cleaner on your rubber intake manifold and those two vacuum hoses to check them for leaks. At idle if you have a vacuum leak there, the spray will raise the idle speed momentarily. As Greasy said, basically you have the correct hose already unhooked. Where your tee is broken.
ET4
ET4
Should I just leave it broken? or seal the tee and keep the carb open? and basically spray the two nipples with carb cleaner and if rises then fix them?
I meant to add sometimes when i open gas cap it hisses, and the problems are more noticeable when im low on gas (maybe coincidence)
@greasy125 avatar
@greasy125 avatar
Remove c entirely. It does nothing.
Ride and report.
But if I had to guess, you’ve got a vacuum leak somewhere.
ET4
ET4
And cap the tee end of c?
@greasy125 avatar
@greasy125 avatar
Don’t know what you’re talking about. Picture please.
ET4
ET4
where I did the black line on th epic below, because If i remove the hose the tee will have an exposed end where c used to be, should I leave it exposed or cap it?
ET4
ET4
New owner having similar issues. With the vacuum line off at the carb, isles great, terrible acceleration and wot is about 20mph.
Hook the vacuum line up and it sputters and dies within a few seconds. There is a slight vacuum at idle when the line is unhooked from the carb when you put you finger over the hose end.
Is the vacuum pulling the needle valve out of the main flooding it out?
Why is the acceleration so poor when the vacuum line is unhooked? Is it not lifting the needle?
[ Time: 0.0117s ][ Queries: 5 (0.0026s) ][ live ][ 318 ][ ThingOne ]
