Piaggio mp3 300
Piaggio mp3 300
Is it any possibility of chip tuning this bike? Or any other possibility to increase the power in any other way?
I have just bought a mp3 300 bike and want to get some more power from the bike.
Does anyone know if it is possible and if yes who do I contact?
2015 MP3 500 ie Business
It is possibly to chip tune them, BUT how much extra do you expect to get from such a little lump? Besides, chip tuning almost always causes extra engine wear and fuel consumption.
If you're only after 1 or 2 extra ponies, then you're better off getting a good exhaust like a Akrapovic.
@maksor avatar
Gilera Fuoco 500ie
@maksor avatar
Gilera Fuoco 500ie
a exhaust won't give more then 0.2 HP to get the promised 2 hp you need to do a lot more like flown the head other intake andd stuff like that
yes its possible you will gain a bit, about 28hp on the crankshaft 22 on the rear wheel better option is buying a wrecked Front demaged Beverly 350 or X10 swap the engine and other stuff then you will have 32hp on the crank
@mono avatar
Hanway RAW50
@mono avatar
Hanway RAW50
Best bet is to fix the CVT first.
With a small engine like the 300, you'll waste a very noticable amount of power whenever the CVT can't keep RPM between 7000 and 7500 at full throttle - which, in the OEM setup, happens quite often..
For my 300, installing dr. Pulley sliders instead of the OEM rollers made a big difference.
(If these sliders wouldn't be available anymore, some day, i'd have to upgrade to a larger bike, since the OEM setup just doesn't cut it for me )
Did you bought Dr.pulley for Hpe 300 Mp3 engine? 2019-2021 model? And if yes which dr pulley? what kind of roller and weight? What did you gain?Lost? Thanks
[ Time: 0.0093s ][ Queries: 3 (0.0027s) ][ live ][ 335 ][ ThingOne ]
