Posts: 838 Location: Naples Florida USA |
The new scoot has a fuel injected engine. I was protecting my carburated engine from the nasty stuff. Should I still do that?
S150 '09, Beo 500ie '08
Posts: 1537 Location: Bermuda |
Ethanol in fuel that gets used is perfectly fine. It’s been around and engines have been designed to accommodate it since the 1970s. Any decent vehicle will have fuel lines that are labeled alcohol-compatible - that’s because of ethanol.
Ethanol in fuel that gets old is problematic for all engines. It absorbs water vapor from the air, which turns into sludge that clogs carburetors easily, and will eventually foul fuel injectors too. That’s all ethanol does. It doesn’t eat through gaskets, fuel lines, carburetors, or anything else. It just gets sludgy when it gets old. So, for small engines: avoid ethanol fuel if you can (this is impossible in many areas, including the NYC metro area), stabilize your fuel with StaBil or equivalent, don’t let untreated fuel linger in the tank for more than six months or so, and drain the tank and fuel system including the carb before layups. Same with carbs or fuel injection. Prevention is 100 times easier than dealing with a cure. |
GTS 300ABS, Buddy Kick 125
Posts: 13555 Location: Oregon City, OR |
As others have said, E10 gas/ethanol blend burns fine in modern engines including modern Vespas. The problem is with E10 in storage. If your scooter spends the winter stored in the garage, or whatever, my advice would be to try to fill the tank with non-ethanol gas (rec gas) and run it long enough with that fuel to purge the carb or injector before storage.
You might get slightly better mileage with ethanol free, but if you have to pay extra or go out of your way, it eliminates the benefit.
RIP
Posts: 8291 Location: Latina (Italy) |
Posts: 11423 Location: Hermit Kingdom |
Attila wrote: Is ethanol that liquid that blinds you? But methanol will blind you. https://www.healio.com/news/ophthalmology/20120331/dr-sadun-honored-for-work-during-blindness-epidemic-in-cuba |
grouper wrote: Do whatever your owner manual says. Up to 10% ethanol is ok in the gts hpe. The manual says up to 10% ethanol and 95+ octane. I can get Rec gas but it’s lower in Octane. I live year round in perpetual summer in SW Florida. So no periods on non-use. |
Posts: 45845 Location: Pleasant Hill, CA |
Billrush wrote: Ahh the owners manual. That’s why I love MV because I get between the lines advice from real experience. Thanks everyone. The manual says up to 10% ethanol and 95+ octane. I can get Rec gas but it’s lower in Octane. I live year round in perpetual summer in SW Florida. So no periods on non-use. https://en.wikipedia.org/wiki/Octane_rating#Measurement_methods |
That’s good. We don’t have 95 octane fuel here anyway.
Leave it to the USA to use a different standard! |
Posts: 12750 Location: Fond du Lac, Wisconsin |
znomit wrote: It's certainly can alter your vision to make members of the opposite sex more attractive. It also makes you think you can actually sing, too. But yeah, you're far less likely to wind up in the hospital or morgue with ethanol...though don't rule it out. I'm good...my scooter could drink about as much ethanol as I do. |
RIP
I happen to live by a lake so rec fuel is easily purchased. I use it exclusively in my BV350. I figure 90 octane of pure gas is better than having some ethanol for a couple of more points.
