Hearing a noise when I let out the clutch in first gear. It’s a 63 GL with a p200 motor. I rebuilt the clutch a few months back. The noise only happens for a second or two when I’m starting from a dead stop in first gear. I don’t notice any noise when I’m using the clutch in 2nd, 3rd or 4th. It almost sounds like the plates are touching the clutch cover.
Moderibbit
![]() 1980 P200E - "Old Rusty", 1976 ET3 Primavera
Posts: 8891 Location: Atlanta, GA |
From the video (never the best sound quality) it's very "rattly" sounding - are you sure it's related to the motor at all and not something like the license plate or some other loose bit slapping when the vibrations hit just the right frequency+power?
A question: does it do it in neutral if you mimic the clutch motions and acceleration? A question: does it do it from start in in 2nd? (you kind of said not, but I wasn't sure if you mean while riding or actually using a different gear in the same scenario) You might pull the clutch cover to see if there's any sign of rubbing, in case you have bearings going and you're getting too much play under certain load conditions *edit* you know, I listened again and I'm sure if it was a loose part rattle (e.g., the plate) you'd hear it when you rev. Sorry. I'd be curious about the answer to those two questions above, but I'd probably go straight to popping the clutch cover and taking a look |
Jet Eye Master
PX221 MHR, PX200 O tuned, PX181 M1XL, PX125 O tuned and some motorbikes
Posts: 4860 Location: London UK |
![]() '64 Motovespa 150S (177) , '65 VBB, '66 Allstate SF, '66 180SS, '58 LD 125 (150)
Posts: 2088 Location: S.Salem, NY |
I tried engaging the clutch from a stop in 2nd gear and it definitely made the same sound, then I “feathered” the clutch lever while the scooter was moving in 2nd and I got the sound again. It seems to be making the noise at the moment the clutch begins to disengage, and I’m guessing now that it has nothing to do with which gear it’s in.
I pulled the clutch cover off and there are no marks on the cover. The clutch and the motor were just recently rebuilt, new bearings, seals etc. I did the work myself and I am not the greatest mechanic! I’ll pull out the clutch and see if I did something wonky with the installation ![]() ![]() |
Vpfalcon wrote: I tried engaging the clutch from a stop in 2nd gear and it definitely made the same sound, then I “feathered” the clutch lever while the scooter was moving in 2nd and I got the sound again. It seems to be making the noise at the moment the clutch begins to disengage, and I’m guessing now that it has nothing to do with which gear it’s in. I pulled the clutch cover off and there are no marks on the cover. The clutch and the motor were just recently rebuilt, new bearings, seals etc. I did the work myself and I am not the greatest mechanic! I’ll pull out the clutch and see if I did something wonky with the installation |
![]() 1979 P150X, 1983 P200E, 1987 PK125XL Elestart, 1988 T5, 1995 PX200E, 2011 Yamaha Fazer 600 S2
Posts: 4609 Location: Veria, Greece |
Sounds to me like the usual problem where the brass bush slips on the base plate. Since you’re pulling the clutch out check it if it’s loose or tight on the base plate. Also use a bit of Loctite 603. I now replace them all with a reinforced one from BGM or SIP…
I’m not sure where I went wrong here, but the first metal plate that I removed is badly damaged. It looks as though I put the clutch back together without engaging the notches on that plate, causing those notches to get bent out of the way when the clutch was disengaged. I’m surprised the clutch still worked
Johnny Two Tone
![]() '15 GTS300, '86 PX125EFL, '66 VBB, '01 ET4
Posts: 9014 Location: San Diego, CA |
Moderibbit
sdjohn wrote: Are all the tabs still attached? Make sure no metal has gone down to the gearbox oil… Also damn... that... good thing you pulled it now |
sdjohn wrote: Are all the tabs still attached? Make sure no metal has gone down to the gearbox oil… Glad I don’t have to split the cases. I ordered a new steel for the clutch. ![]() |
