So, I'm having new tires put on my 2011 GTV, and when I removed the rear swingarm to remove the rear wheel, I noticed that the main bearing is feeling gritty.
I don't have a bearing press in the garage, but I figured I'd go caveman-style as my dad and I used to do when rebuilding engines back in the 70's. I'll get a torch, heat up the swingarm, and pound it outta there. That'll probably do for removal, as it won't matter if I screw up the bearing getting it out.
I'm going to have to find a suitable drift to drive it back in, though. I suppose I'll give it a try first to see how badly I can screw it up...haha.
Anyone else done this as a home repair? At least the bearings are cheap - $8.95 from Scooterwest. I figured it's inexpensive enough to take a shot, anyway...
