Hi Community
my Vespa GTS 300 only 2.5 years old - from 2018 and just out of the warranty - had a faulty ABS pump which was leading to a stuck brake lever. The lever was sitting rock solid and couldn't be pulled any more.
When it happened to me I was caught by surprise and nearly hit a car.
I found already two post describing the same or similar symptoms.
I am wondering if more of you experienced the same issues?
If it turns out to be a common problem based on manufacturing problems I see a massive safety concern which needs to be shared.
Vespa dealer charged 1000 Dollar to replace it.... funny enough he had the spare parts right on hand....
