Hey gang,
My scooter is nearing completion (thanks to those of you who have helped me along the way) and I am now tensioning the cables. I have the clutch cable at a good place where there is only 2mm of play at the lever. The rear brake as well is grabbing well and returning to position.
My problem at the moment is the front brake. I am using a 3rd hand tool to maintain tension, but even with that, the brake lever will not return naturally, and the brake cam seems a little stuck at the hub. Is there a simple solution to make the cam twist smoothly? I really don't want to have to take the front hub assembly apart, so can anyone help with the tension issue and the cam issue.
As always, thanks for the support.
