Hi all,
Over Covid I decided I wanted to try to build up a p-series from scratch. Definitely an "amateur resto" but intended as a learning experience.
I'm currently working on getting the floor rails on; I have the SIP riveter, an amazing tool. The problem is the final rivets on the outer rails, where the rails overlap with the trim. I started off using the crimp-on trim, which I promptly destroyed when attempting to use the factory crimp tool. So I ended up using the plastic "chrome" snap-on trim instead.
The photo shows the issue. There is a large gap between the floor rail and the legshield due to the trim. I tried drawing it down with the rivet, but the large gap meant that the rivet just mushroomed along the shaft.
I'd rather not cut the trim but am not sure how I am supposed to get the rail flush enough to rivet. Any advice would be much appreciated.
