@mopedlar avatar
2001 GTS Super (white), 2021 GTS Super (yellow), 1976 Bianchi Snark moped, 1980 General 5 Star moped
@mopedlar avatar
When I went to open the trunk on my 2005 Vespa GT 200, the top half of my trunk came off. I found one of the hinge pins/rods, but the other pin is MIA. I can’t be the first one to lose one of these pins, so what can I use as a suitable replacement. TIA.
'08 Vespa LX80, '07 LX50
I think anything with a suitable diameter like a nail or section of rod will work. If yours is like mine one end is knurled and that keeps it in place. If it fell out I would insert it back in the opposite way if you can by squeezing it into place in one motion and you can peen a few bumps into your new one. A center punch works good to make divots that are almost as good as a knurl.
@mopedlar avatar
@mopedlar avatar
Thanks for the advice! When I got home, I found an old metal dress hangar (not the cheap, bendy metal ones), and cut it to size. The diameter of the metal was just about perfect. Problem solved!
@vintage_red_matthew avatar
MV Santa
MV Santa
That will work but I suggest you try to find a replacement made out of brass or stainless steel so it won't rust.
Matthew is totally right but if the hanger was made from good metal you might be ok. I actually went to the hardware store and got a matching diameter aluminum rod and used a hacksaw to cut to length and put a bunch of divots in one end with a hammer and center punch to create the interference.
@mopedlar avatar
@mopedlar avatar
Thanks for the tip! If it starts to rust, I’ll replace it with an aluminum rod.
@fudmucker avatar
@fudmucker avatar
Bicycle spoke?
@nightwing avatar
Contributor
2007 LX 150 (memories)
Contributor
@nightwing avatar
Piano wire available any place that has the K&E display of brass and copper tubing. Most hardware stores have them and all hobby shops have them but those are getting hard to find. Hobby Lobby carries them.
@syd avatar
GTS300 Super (Heinz) GTS250 Super (Bulger)
@syd avatar
Stainless machine screw with locking nut.
2018 Gts 300
2018 Gts 300
Old drill bit.
GT200l
GT200l
This happened to me recently as well.
[ Time: 0.0101s ][ Queries: 3 (0.0025s) ][ live ][ 313 ][ ThingOne ]
