@mike_dee avatar
2015 GTS 300
@mike_dee avatar
2015 GTS 300
I'm currently having some issues with a 2015 GTS stalling out at low speed/idle when coasting to a stop. Came to the hive mind to start researching the potential root cause and hit a bit of a wall when using the search function. I recently installed an akropovic pipe (about 500 miles back) and wanted to do a search to eliminate that as a possible cause.
Error capture below is from searching "akropovic remap". I realize that MV just went through a significant s/w update and was just wondering of this is somehow related or if this is me being less than skilled at using the search tool?
Side note - I searched some other common words like dog and got several pages of error codes.
Cheers,
Mike Dee
Error results
Error results
Hmmm, search is working fine for me. Though its akrapovic.
You might want to use google (and hurry, before Jeff blows up) :
akrapovic remap site:modernvespa.com
@mike_dee avatar
2015 GTS 300
@mike_dee avatar
2015 GTS 300
Glad to hear that the search function works for other users.
I initially thought that the error was related to spelling Akrapovic incorrectly but then I searched GTS and got about 20 pages of error codes. Tried again just now and cannot get any results for any search string or single term search.
Mike Dee
What browser are you using? have you tried a different one.
@mike_dee avatar
2015 GTS 300
@mike_dee avatar
2015 GTS 300
Errors persistent in Chrome, switched to Edge and bingo, problem solved.
Should have thought of that solution myself - thanks Matchlessman.
You are welcome, Interestingly, i'm using Chrome and the search works ok So maybe its down to the version of Chrome or windows.
Thanks for the report. This is a mysterious error that has happened once before (see: Primary key issue when searching). It shouldn’t be possible, but it still appears to happen. As this is only the second time I’ve seen it, it’s still rare, but I’d like to find the root cause.
Generally, it should go away on its own, when the previous search results get pruned after some inactivity. That’s little solace, I realize, but that’s as much as I know about it so far.
[ Time: 0.0114s ][ Queries: 5 (0.0032s) ][ live ][ 334 ][ ThingOne ]
