@jayn avatar
05 Px150, 74 primavera 125, Honda super cub
@jayn avatar
Have to do 2 posts (can’t post more then one pic at a time)
This is what plug looked like after long fast ride on Thur.
@jayn avatar
@jayn avatar
3 days later - same plug after a shorter ride (no more then half throttle). What gives? Air leak?
@christopher_55934 avatar
2007 Stella 225
2007 Stella 225
An air leak is possible. It can also be throttle position differences, you have an idle jet, midrange mixer and main jet if your still running a SI carburetor. You also have the throttle slide which can have cut outs depending on the slide.
Without going into a lot of detail each jet affects mixture at a throttle position and can be additive.
Here's a quick intro to a few parts.
⚠️ Last edited by Christopher_55934 on UTC; edited 1 time
You can. Just hit “Add Attachment” after you’ve selected the first file, then you’ll see a new “Choose File” button to add the next image.
@jayn avatar
@jayn avatar
Sorry, should have specified -
Dellorto phbl 24mm. Strange to me that one day plug looked good, next ride looks lean.
2007 Stella 225
2007 Stella 225
I have a phbh on a scooter, you still have a few jets and a needle.
Jet Eye Master
Jet Eye Master
To me both pictures look as bad as each other. If it doesn't seize, then it is doing damage, kind of colour. Stop riding it. Assess the damage. Re jet completely.
Good news is, if the plug is that colour it will be really slow.
[ Time: 0.0148s ][ Queries: 4 (0.0074s) ][ live ][ 343 ][ ThingOne ]
