@mitleider avatar
2024 GTV & 2024 GTS Supertech
@mitleider avatar
Hello all,
Unlike the rest of world, U.S.-spec Vespas come fitted with large and unattractive chrome highlighted front and rear fender reflectors. These are affixed via holes drilled in fenders and attached with grommets.
I’m looking for a less visually invasive, lower profile, aftermarket substitute.
I’m not interested in plugging the holes with perhaps equally ugly plugs.
Any suggestions would be appreciated. Thank you!
@greasy125 avatar
@greasy125 avatar
Reflective tape, cut to the shape and size you wish and color you want.
'08 Vespa LX80, '07 LX50
I never got around to it but I was thinking like you and ordered these. I was going to try one in each hole but decided to stick with stock. You can get them in Amber for the front and red for the back.
https://www.amazon.com/gp/product/B002FDPQH2
@guzzi_gal avatar
Gigi, '13 GTS 300ie Touring
@guzzi_gal avatar
I removed them and inserted the pre-painted scooterwest plugs but I like the idea of reflective tape if you still want the visibility.
https://www.scooterwest.com/custom-painted-plug-kit-for-reflector-removal-rplugsx-3.html
2019 GTS300
2019 GTS300
I know hole plugs aren’t the most elegant solution, but Scooterwest has “pretty” plugs. Probably not what the OP is looking for, but other readers could be interested.
https://www.scooterwest.com/custom-painted-plug-kit-for-reflector-removal-rplugsx.html
[ Time: 0.0128s ][ Queries: 4 (0.0043s) ][ live ][ 331 ][ ThingOne ]
