Well I bought this little fella today locally. It’s a pk75 xl , a little ratty but considering 34 years old in pretty good shape. Surprised at its power for such low capacity and everything mechanically good. Other than some minor repairable dinks and bit of paintwork required not much to do. Got to register with a uk plate . The seat is so comfortable and it’s so damn light too. I’m going to kit it with a 135 of some description and have the engine gearing , crank upgraded at some point. Think it will be a cracking little local runabout down the line. What kits do you guys recommend ? DR, malossi, polini? Thx
![]() ![]() Pk
![]() Pk
![]() Pk
Posts: 719 Location: UK |
It looks solid!
Was the motovespa 75 the one with the ali barrel? If so then I have a feeling that the spigot size is different from the rest of the smallframes (apart from the early 90) and might not be suitable for putting a kit on. |
Matchlessman wrote: It looks solid! Was the motovespa 75 the one with the ali barrel? If so then I have a feeling that the spigot size is different from the rest of the smallframes (apart from the early 90) and might not be suitable for putting a kit on. |
![]() UTC
'81 50 special,'57 GS150 VS3,'59 152L2,'60 SII Li150
Posts: 213 Location: The garden of England |
![]() '81 50 special,'57 GS150 VS3,'59 152L2,'60 SII Li150
Very nice. And in good nick too. Some PK parts are getting thin on the ground now.
I bought a frame with a few other bits a couple of weeks ago for a future project. I will gradually collected the bits to do it. I already had a set of VMX5M engine cases in my smallframe stash. This one is an 86 PK50XL. ![]() |
They are getting more difficult to get hold of now as imports. The cost has gone right to ship and taxes too so doubt many will find their way to uk. I paid 1200 quid for it so think done ok as all small frames are getting harder to get. I love how light it is, really easy to move about.
Neil Edgar wrote: Very nice. And in good nick too. Some PK parts are getting thin on the ground now. I bought a frame with a few other bits a couple of weeks ago for a future project. I will gradually collected the bits to do it. I already had a set of VMX5M engine cases in my smallframe stash. This one is an 86 PK50XL. |
ferriswolf wrote: The xl2 yes but not the xl. Its fully supported in all the kits . The xl2 has a short stroke for some reason. I checked this before deciding . |
![]() UTC
Posts: 900 Location: somewhere deep in the back of the garage...Burlington ONT. |
![]() '07 GTS250ie "Mechanical Squirrel", '66 Honda Benly, '19 Suzuki 250 cafe "Mouse", '42 Henschel PzKw VI Tiger
Thats a really nice little bike.
Motovespa, wasn’t that the name assigned to Spanish built bikes or am I mixing this up with one of the other makes that had works in that country. |
Fritz Katzenjammer wrote: Thats a really nice little bike. Motovespa, wasn’t that the name assigned to Spanish built bikes or am I mixing this up with one of the other makes that had works in that country. ![]() Vespino motovespa
![]() Vespino mv
![]() Vespino special
![]() UTC
The yellow one comes with a shoe already attached to the right hand pedal?
Cool factory accessory or bad photo editing... i dunno. I started out on a moped a zillion years ago. There never were acceptable over here in Canada so my first riding experiences were a mixture of joy brought on by this newfound freedom and horrible embarrassment cause by the knowledge that my ride was totally uncool. The freedom aspect won out |
Moderibbit
![]() 1980 P200E - "Old Rusty", 1976 ET3 Primavera
Posts: 8891 Location: Atlanta, GA |
![]() UTC
P Series / Li / LML / Motobi
Posts: 511 Location: UK - 3rd Rock From the Sun |
![]() P Series / Li / LML / Motobi
if you ever want another one....or are struggling for parts - i have a contact in spain and could do go between for you
im in wolverhampton |
Gravelrash2004 wrote: if you ever want another one....or are struggling for parts - i have a contact in spain and could do go between for you im in wolverhampton |
Why on earth would my 75 cc be fitted with a 20mm Delorto carb as standard. This is something that would be on an et3. Has the 75xl got more ports on it or something? Anybody know?
![]() UTC
You were surprised at the power for such small capacity. Maybe its been kitted already.
Smells like a 110/112 kit, perfect for a 20mm carb. |
Neil Edgar wrote: You were surprised at the power for such small capacity. Maybe its been kitted already. Smells like a 110/112 kit, perfect for a 20mm carb. |
![]() UTC
The Motovespa PK75 is a unique engine 47mm bore and 43mm stroke (like the 50's). a 135 kit will work if the crank is changed for the the 51mm stroke 125 crank. This engine also has a 97mm long conrod, the same as the 125 motors. So both 112 or 135 kits are not bolt on without changing other parts. Be interesting to see what you've got.
I was informed that this is true for the xl2 not the xl1. I’ve gone to two main suppliers now and my engineer who inform me the xl1 has longer stroke so bolt on. When you look at kit compatibility lists xl is in there but not xl2. I hope they are right . But thanks for your input. There was a German pk75 too manufactured and that looks just like a 50 special but has the primavera side panel toolbox . The 75 kit was the original kit of choice in the 80s for a 50 upgrade. It appears the 20mm carb is standard for xl75 as i found a YouTube of a Spanish owner servicing his 75xl and he does a carb tear down , it’s delorto 20mm., when push comes to shove be happy for now to get it on road just as is and drive as 75cc until the next season. I doubt with dvla in the uk they will register for ages due to covid isolation issues with staffing.
![]() UTC
Posts: 1614 Location: Tucson, AZ |
![]() 71' Sprint Veloce , 05' Vespa PX150, 1978 P200E
This post brings me good memories, this PK that you have has Barcelona plates. It is the same color and year as the one that I had. Mine also had the security flexible metal tube that connects from the left of the handlebar to the post near the seat, in Spain we call it "piton", it is probably the number one accessory that you but from the dealer. My mirror was square (yours is rounded).
Yes it lived for 18 years with same owner in Terrassa. Got 16k on clock so guess it’s been pottered about local. The security device is very good as you can pop horn casing off and simply short the ignition plug and off you go if steering lock not on.
Petrus wrote: long time no nothin´ so got to ask: how did the project go? |
thanks for the update.
Good reliable little runabout the. Good buy!! Whishing you luck/success with your undertakings thus more spare time for the scoots. |
