2005 GTS 250 horrible noise from the back end. After removing the CVT cover and finding no obvious culprit I whipped the exhaust off to get to the swing arm. When I found that the bearing was shot I was quite pleased that it wasn’t a more internal issue.
However, I was left with a swing arm with a jammed in outer bearing race. So how to remove it? I don’t have a blind bearing removal tool but there was no gap to get behind the bearing. I tried drifting the bearing out after heating the swing arm but the only purchase was oblique and ineffective.
Back to some internet research.
I found info about dremmeling the bearing, welding a slide hammer to it. Etc etc.
I expected collateral damage due to my inept dremmel use and I don’t have a welder. So I decided to use toilet paper.
Yup, toilet paper.
I managed to get 5 of the ball bearings back into the bearing and the packed wet toilet paper between the equally spaced balls. The balls in the packed race held the inner race secure. I then heated the swing arm and placed a socket on top and whacked it with a hammer. Hey presto bearing popped right out.
I hope this helps anyone in the same position. [/img]
