So I have been looking for a 300 for a while so I can park my 2stroke for more extensive mods
It turns out it pulls to the left... a lot, so i took it to my trustworthy mecaninc and replaced the steering column bearings and now it continues to pull to the left but is less evident or the pull is not as strong.
Some friends and my mecanic rode it and say that I should just forget about and enjoy buuuut I want to replace the steering column the problem is it is expensive and I am not sure is only the column, what if the frame is also bent, any ideas how can I check if the frame is bent or if is only the steering column that is bent?
