Hi all!
Sorting through the bike has been fun. I’ve stumbled on a new challenge.
I got it running pretty well. Carb is tuned properly, clutch is working right, shifting is easy peasy, and it was starting first kick daily.
I noticed the key switch wasn’t killing the bike and the kill switch just blows fuses so I leave it be
It was starting without the key so I decided to find out what was going on.
Opened the head set up and noticed the green wire that connects to number 8 was clipped at the connector.
Opened the horn cast j box and noticed the green wire from the kill switch box was soldered to the purple wire from the headset and plugged into the purple female connector. So I took it all apart and crimped on a new connector for the number 8 green. Tied the killswitch green to the double green that goes to the back of the bike and everything looks like the diagram from scooterhelp.
But now I get no spark
Then it got dark so my work day is done
My guesses are
I have a short ground somewhere in the greens
Or
The switch is fricked.
Taking bets
I’m get out with a multimeter tomorrow and find out
But I’d also welcome other theories or possible bugs to look at
Thanks!
