BUT for starting points have any of you changed from a Malossi Power (expansion pip) to a Polini and did you need to rejet
I have a Malossi P210 port matched cut away crank with PHBH30 carb currently running a Malossi expansion pipe but have just bought a Polini Expansion Box for the bike and to change over was wondering if there is usually a BIG need to change the jetting.
it would be easiest to start with current jets BUT dont want to run lean and seize...
My assumption is it should be the same or at least similar BUT wanted to make sure 1st. if anything I assume it may be too rich or so I am hoping then I can easily down jet as too rich wont damage anything compared to too lean
THOUGHT PLEASE
https://scooterlab.uk/vespa-big-box-exhaust-shootout-feature-2/
Polini as per this article
⚠️ Last edited by themod1 on UTC; edited 2 times
