@grouper avatar
2020 GTS 300 hpe Touring
@grouper avatar
We have just built a new garage, and I have been thinking about a table to raise my Vespa up to a good work height. I wanted to be able to get it out of the way when not being used, and what I came up with is a table that is hinged so that it folds up against the wall when not in use. The two legs are also hinged and swing down into position when the table is lowered. It's made from some odd pieces of 1/2" Baltic Birch plywood and 2x4s. The legs (plywood glued and screwed to 2x4s) are plenty strong and support the main frame of the table. The two odd strips of plywood on the floor (a temporary solution until I can think of something more elegant) ensure that the legs stay locked in place. The right side of the chock is bolted in place, but the left side is adjustable so it can clamp the front tire. The table height is about 21 inches so it's pretty easy to push the scooter up the ramp by myself.
I haven't really done any maintenance yet, but it's great to get the bike up there and give the lower half a nice sponge bath without getting on the floor.
@jezibel_tires avatar
ET4
ET4
Thats amazing! did you seal it with anything? in the interest of oil/grease stains/smells
@grouper avatar
@grouper avatar
Thanks. I haven't put any sealer on the 2x4s, but all the plywood was scavenged from a cart I took apart, and I had sealed it with polyurethane years ago when I built it. I guess I should at least seal all the edges again. The chock plywood was not from the cart, so it has no sealer on it. I will get to that eventually.
@kimpossible avatar
Tethys - 2012 GTS 300
@kimpossible avatar
What kind of ramp is that?
@retro_scoot avatar
2023 GTS300, 2021 Sprint
@retro_scoot avatar
Well done!!
(And a garage to die for Clap emoticon )
@guzzi_gal avatar
Gigi, '13 GTS 300ie Touring
@guzzi_gal avatar
That's a cool build and I'd love plans to go with it. That said, I'm in awe of all the space you have in your shop!
@grouper avatar
@grouper avatar
Kim, first of all congratulations on your Cannonball adventure. You did really well, and I was rooting for you. The ramps are from Home Depot but I found this pair gently used on FB Market Place listed for $160. I offered her $140 and she jumped on it. We were both happy with the deal. Here's a link:
https://www.homedepot.com/p/CargoSmart-12-in-W-x-90-in-L-750-lb-Capacity-Hybrid-S-Curve-Centerfold-Truck-Loading-Ramp-Includes-1-Ramp-3086/300563111
@grouper avatar
@grouper avatar
Thanks...I would give you plans but I don't have any. My only drawings don't have dimensions. That's just the way I work; I make pieces fit as I go along. The pictures should suffice as plans, and I will be happy to give you any dimensions you want.
@guzzi_gal avatar
@guzzi_gal avatar
I can figure it out as your pictures are very clear.
If I can get my husband on board with a few days of very hard labor, I think I could get us more usable garage space for such a wonderful addition.
@grouper avatar
@grouper avatar
Retro Scoot wrote:
Well done!!
Thanks Retro. My wife and I both love the empty space in the garage so we are doing our best not to fill it up. At our age we are more in 'throw away' mode rather than 'find another place to store it' mode.
@nickj avatar
2009 S 125
@nickj avatar
2009 S 125
That's a lovely bit of work I'm feeling quite jealous now Thanks for the clear pics though.
@retro_scoot avatar
@retro_scoot avatar
I hear ya! Same mode in our life. But beware, “The Universe abhors a vacuum”. According to the laws of nature and physics, empty or unfilled spaces are unnatural and that wherever there is a void, the Universe seeks to fill it.
Just try to fill it with the right stufff.
A red one, a blue one, and white is always nice… maybe a nice small-frame to compliment the 300. You get the idea.
It’s inevitable. AMHIK
Is that the same universe that is 99.999999999999999999958% vacuum?
@attila avatar
@attila avatar
Grouper didn't fill an empty space, they just moved the Vespa (occasionally) higher. I would add, if the table was apparently rotated 90 degrees and hinged on the long side it would also serve as a parking space for the Vespa.
@baba12 avatar
2018 Vespa 300 GTS Touring
@baba12 avatar
Damn cool. Envious that you have the space but more importantly that you have put it to good use and the table looks awesome.Thanks for sharing the details of the build.
It will be great to be maintaining the Vespa in such a clean garage space.
@retro_scoot avatar
@retro_scoot avatar
That last tiny fraction was my garage.
[ Time: 0.0145s ][ Queries: 4 (0.0082s) ][ live ][ 323 ][ ThingOne ]
