@petere avatar
1981 P200
@petere avatar
1981 P200
This is a weird one. I just installed new seals, cross, and rewired the stator. Put it all together and it fired right up. Road around a little yesterday with no issues. Today, there was some backfiring then missing under load then it died. It will idle but as soon as the clutch cover lever moves, she dies. The tiniest movement of the lever at the clutch cover kills it. Any ideas?
@charlieman22 avatar
Nedminder
Nedminder
I would rule out air leak first.
Did you pressure test when you completed the work?
Soapy water in spray bottle, and pressurize the motor (lots written on how). Spray it over on the clutch side (as well as all over) and look for bubbles.
@petere avatar
1981 P200
@petere avatar
1981 P200
Thanks. I didn’t pressure test it yet. New point of information: It happens when it’s hot, runs great when cold.
@scootermarc69 avatar
What model?
My first step would be to disconnect the green kill wire from the cdi. If this solves it you have a short that grounds out when the clutch cable stiffens under load.
@killo avatar
I have a few scooters....
@killo avatar
I had a brand new seal almost turn inside out when I installed the crank. I didn’t notice it when it happened. It ran fine at first but got worse and worse.
@gt6mk3 avatar
Bodgerific 150 Super, PX200(ish...), US 50 Special in progress
@gt6mk3 avatar
This!
Jet Eye Master
Jet Eye Master
Clutch nut come undone and crank moving?
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
I'm with Jack - maybe some lateral movement (even without a loose nut) combined with pickup location for the CDI could be leaving you without a trigger. You may need to shim the pickup.
@petere avatar
1981 P200
@petere avatar
1981 P200
I tried disconnecting the green wire from the kill switch with no effect. A friend had a rebuilt stator on hand to swap for my self-soldered one. In the process of switching them I discovered that the purple wire from the stator to the regulator and the ground from the stator were touching in the junction box. I put them in their proper slots and the problem went away! Why the clutch had any effect on this is still a mystery to me. Thanks for all the suggestions.
[ Time: 0.0127s ][ Queries: 3 (0.0037s) ][ live ][ 313 ][ ThingOne ]
