GTS 250
GTS 250
I recently replaced the fuel pump on my 2007 GTS following the Cheeky-Thomas instructions (https://cheekythoma3.wixsite.com/itsme/fuelpump). It failed to even turn over once I got everything back together. It appears to lose power when I turn the key on (the digital clock goes out). When I turn the key, flip the kill switch, engage the brake and hit the start nothing happens. I turn the key off and the clock comes back on but the button for the seat opening stops working. When I open the seat with the lever in the glove box it enables the button to work again. This seems electrical to me, but I am not sure. Did I not put something back together properly? Any suggestions on what I should be checking? Appreciate any tips. Thanks!
That sounds like a dead battery, or severely compromised battery connections. Get your battery tested.
try to recharge the batter how previous suggested. or use a jump starter
PS : have you replaced the fuel filter too ?
[ Time: 0.0094s ][ Queries: 3 (0.0034s) ][ live ][ 313 ][ ThingOne ]
