@gravelrash2004 avatar
P Series / Li / LML / Motobi
This is a question i never thought i would ask.....
i have in my posession a mazzuchelli crank that someone has brayed from an engine wiith a mallet......
Q. Does anyone know the thread and pitch on the flywheel for a P Range motor?
i can then clean it up before i get it trued up again.....
some people are animals!!
Thanks in advance everybody
@greasy125 avatar
@greasy125 avatar
ohhh... I have JUST the tool for fixing that... but I'm half way around the world.
however, I'm not right in front of my tool box at this very moment...
I can get it for ya later and show you the bit of kit that you'll need to make your life easy.
@safis avatar
@safis avatar
It's M12x1,25mm...
Greasy - i would love to see this miracle tool and it it to my collection
Safis - Thankyou M12 x 1.25 - Die on order and im patiently waiting for the arrival
@geeklion avatar
The Dude
The Dude
@geeklion avatar
Seconded!.... Not gonna lie, a little confused and extremely intriqued by this miracle device of crank correcting miraculousness!
@philos avatar
2001 LML 150 2t
@philos avatar
2001 LML 150 2t
I would be choosing a thread file as the tool for this job…. then run a die over it.
@Greasy
Enquiring minds want to know what this magical tool is.... have you had the opportunity yet to take a photo etc?
@gickspeed avatar
@gickspeed avatar
Set of calipers and thread pitch Guage will give you the measurement. Then a tap will clean up yours threads
A die, right?[img]
I’ve used this thing to repair threads. It works great. Twist the knob to put the two cutting blades into the thread and then turn to clean up the threads. It works in a similar fashion to a pipe cutter.
@gickspeed avatar
@gickspeed avatar
nomadinsiam wrote:
A die, right?[img]
Yes, die.
The problem with that tool is the length of the threads usually is not long enough for it to work. You may get lucky if it’s in the right spot. I have that tool and rarely use it.
It works well for light weight stuff but may not be enough for crank threads. I’ve used it successfully on a rear axle thread.
Thanks all
some excellent suggestions and a tool i have never seen before as well... a truly information goild mine is the "brain trust" of the people on this site
[ Time: 0.0089s ][ Queries: 4 (0.0029s) ][ live ][ 313 ][ ThingOne ]
