paggio mp3
paggio mp3
I have bled the system, replaced switch, replaced pressure sensor.
When I turn the key on the tilt lock does not activate. It may take 20 times of on off , then it will come on. Once it’s on everything is perfect. What else can I check. I have disconnected the battery and cleaned the terminals and the wires to the battery. Hopefully I the morning it will be ok.. any hints please.
paggio mp3
paggio mp3
The previous owner has disabled the seat sensor with a resistor, could this be the cause of my problem.
yes
paggio mp3
paggio mp3
I have replaced the resistor still the same. Has anyone had a similar issue please.
2015 MP3 500 ie Business
Errrr . . . . you need to remove (not replace) the resistor.
The resistor bypasses a portion of the electronic components of the tilt lock
It simulates the seat sensor resistance when a rider sits on the seat. It should be a 3k. I presume the seat sensor quit, so the previous owner added the resistor.
paggio mp3
paggio mp3
I repaired the seat sensor soldered the wires and it works fine.
Previous owner must have broken the plug.
[ Time: 0.0090s ][ Queries: 3 (0.0015s) ][ live ][ 313 ][ ThingOne ]
