Another wiring question--where do the rear turn signal wires that are underneath the gas tank (with female spade connectors) attach to? I get that they need to run juice into the cowl, but don't feel any tabs or anything.
@xantufrog avatar
Moderibbit
Moderibbit
@xantufrog avatar
The power comes through this little socket shown in this thread: p200 cowl latch and power socket - how do you remove 'em?!?
Basically, there's a wire held by tabs to the contour of the cowl, that runs from the light forward to the front. There, it ends with a little copper tip that sticks out of the cylindrical tube by the latch. That tube inserts into the plastic socket on the frame that you see in this image
I can take pictures of my own later if that doesn't make sense/you need more
Thanks Xantu; I've got that plastic bushing on order from Scooterwest. My issue is that I'm not sure what to do with the turn signal wire from the loom end -- how does *that* end up in contact with the cowl post that sticks through the plastic bushing into the body?
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
the plastic bushing has a wire and a terminal inside it (with a pigtail) that connect the loom to the post
@xantufrog avatar
Moderibbit
Moderibbit
@xantufrog avatar
yackee wrote:
No problem! I'm not sure I completely understand the question - basically, the wiring on the loom end terminates at that plastic socket/plug...
... which has a little spring-loaded metal contact inside.
The wire on the cowl side that I alluded to has a metal tip...
... that is simply pressed against the socket's contact when the cowl is in place and the metal tube shoves it into the plastic socket on the frame
Thanks again guys! Much appreciated. My Stella's cowls are so different.
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
yes they are like later PX cowls instead of early P, which is most common in the USA
@xantufrog avatar
Moderibbit
Moderibbit
@xantufrog avatar
wait are you working on your stella or a p2?
[ Time: 0.0133s ][ Queries: 5 (0.0055s) ][ live ][ 313 ][ ThingOne ]
