@moto64 avatar
@moto64 avatar
Do the springs get weak over time ? What are the typical symptoms of a bad cush drive ?
I have a pretty obvious rattle right between on-the-gas and off. I can roll the throttle in and out of the sound at pretty much any speed above about 30. I had a similar sound with an exhaust leak on two other two strokes but this sounds more metallic and the exhaust is buttoned up tight. I also pulled the clutch and it's all sound.
I have isolated or eliminated virtually every vibration I can find but this sure sounds internal and was wondering if it's the cush drive ring gear and the X-mas tree rattling between driving and being driven. Make sense ?
Edit: did a google search and found some posts. Sounds like a CD with bad/broken springs mainly causes what feels like a snatchy clutch. That is not the case...smooth as can be. I guess I could always pull it out and take a look.
1968 VBB150
1968 VBB150
Maybe this is the life of an SS owner- ride, pull motor. disassemble. Reassemble ride more lol
@killo avatar
I have a few scooters....
@killo avatar
I think if your cush springs are broken, you'll also get more of a clunk when changing gears too.
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
You’ll usually feel broken cush springs pulling away from a stop ... scoot will lurch and buck when the clutch is released. Sometimes hard to distinguish from grabby clutch, so rule out clutch first.
I had a similar rattling noise in my SS clutch as well. It was the usual, pull the clutch lever in and it quiets down. The cush drive was rebuilt so couldn’t be that, but after further inspection of the clutch, I noticed the gear cluster that is riveted to the plate furthest back was loose. I just peened the rivets down tight. That made a lot of difference. Now it is much quieter. Maybe check that on yours.
@moto64 avatar
@moto64 avatar
Thanks. I just had the clutch out and didn't notice anything wrong with it but of course I didn't take it apart. There's no noise or change in noise when I disengage the clutch nor does it feel grabby but it is pretty easy to check that again.
[ Time: 0.0121s ][ Queries: 3 (0.0040s) ][ live ][ 313 ][ ThingOne ]
