@velasquez avatar
1978 P150X; 1982 P200e
@velasquez avatar
Hi All,
I had to replace the clutch side seal in my P200. Once I put the bike all together I am having a hell of a time shifting. Like I have to grab shift bar with both hands to put it into first. With the gear selector box off and back wheel off the ground I can easily spin the wheel and pull on the gear selector rod and go through the all the gears. I’m thinking something off when I re-installed the clutch. Any tips on where to start troubleshooting?
Thanks,
V
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
Clutch cable adjustment, based on the 2 hands comment
@108 avatar
V range 50s
@108 avatar
V range 50s
+1 on the clutch cable adjustment.
I'd double check the selector box cables too, but i doubt you adjusted it, since changing the seal, but something to relook at if the cases have been split.
@gickspeed avatar
@gickspeed avatar
Poor clutch cable routing; too long of a clutch cable outer.
@velasquez avatar
@velasquez avatar
Thanks all, will check the clutch cable routing this weekend
@velasquez avatar
@velasquez avatar
Went through all the cables and I think my gear selector cables weren’t tight enough Facepalm emoticon . I thought it was something more drastic. Thanks all!!!
Next question: how do I get rid of the extra length on the gear cable, do I put some solder on it and then cut off the extra length?
Yep. Turn the handlebars, make sure you have enough slack, heat and take of the metal finial, back out the inner cable, cut the outer cable, reinstall the finial, solder and trim the inner cable, set the clutch back up. Done. This works for the clutch and gear cables. Good luck
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
If you just have extra inner, you can do as you suggested, solder and snip
@108 avatar
V range 50s
@108 avatar
V range 50s
Adjusting the gear box selector cables right?
If I’m not misunderstanding, for cable slack, you shouldn’t need to solder, adjustments done with 2 small wrenches
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
Many times cable inners have inches of extra length, thus the need to shorten
I just cut them down to size and whatever is left over (about an inch or so) gets a cable end like on a bicycle. Dunno if they will work on the shift cables since they are covered in the shift box, I'll find out soon though.
I had to do just that. My shift outer cables were too long and it was causing it to pretty much not change gears at all. Once the outers are the right length (not too short and not too long; don’t ask me how long that is) shifting will be fine.
@ray8 avatar
@ray8 avatar
You don't really "need" to solder the ends, even when replacing the cable. Any flare at the ends won't make it to the punch bolt.
Helps to have bike cable/housing cutters. Doesn't start the fraying like pliers or electrical wire cutters. Cost around 13 bucks on Amazon
About housings, a factor can be not seating them properly at the headset, rendering the adjusters at the shifter useless.
@velasquez avatar
@velasquez avatar
I had plenty of length left over on the inner cables. Coated them with a little solder and cut the extra length off with no fraying. First one was kind of messy but second came out better.
Thanks all.
[ Time: 0.0133s ][ Queries: 4 (0.0039s) ][ live ][ 313 ][ ThingOne ]
