Vespa GTS300
Vespa GTS300
Recently had my GTS totalled and picked up a Sprint 150.
Yesterday I started having an issue stalling when i hit large bumps in the road - no big deal i thought, had the issue with the GTS that turned out to be a loose battery connection. Checked the battery, that was fine, spark plug, fine as well.
Today when trying to find the culprit the bike starts just fine, will gas fine on the stand but when i put it down and try to accelerate it dies.
Then i realized it was dying every time i turned the steering wheel all the way to the right (even on the stand).
Any ideas? It's driving me insane! What The? emoticon
Probably linked to the spark plug lead. The coil is attached to the frame, not the engine, so as the suspension moves (coming off the stand, or hitting a bump) the lead flexes.
The all the way to the right thing is puzzling though...
I'd open the bar covers to clean and reconnect all the switch-gear connectors, especially the leads to the cutoff switch. Gremlins thrive in bad connections.
[ Time: 0.0092s ][ Queries: 3 (0.0035s) ][ live ][ 313 ][ ThingOne ]
