@chatis avatar
1963 Vespa VBB, 1965 Allstate Cruisaire, 1974 Vespa Super, 1980 Vespa P200, 2003 Stella 2T, 2008 Steall 2T, 2022 Royal Alloy 150 GT
@chatis avatar
Working on a friends Allstate we ran into an unusual issue (for us anyway).
Putting the engine back together after a repair that involved splitting the cases the kickstart seems to disengage when the clutch cover is tightened. Clutch cover loose the engine turns over with the kick start. Tighten the clutch cover down and the kick start does not turn the engine.
Video Here: https://youtu.be/ztn-oy1YfCc
Any ideas??
@safis avatar
@safis avatar
Clutch not fully seated, wrong washer behind it, assembly issues (if you opened up the clutch). Definitely clutch related, cover is pushing it, that’s why it slips…
@chatis avatar
@chatis avatar
We actually didn't remove the clutch at all until this issue started. After removing the clutch cover we were surprised that it started engaging.
parallelogramerist
parallelogramerist
And to add a little bit more to what Safis said, is it still the stock clutch or is it a larger aftermarket?
@chatis avatar
@chatis avatar
I believe it is still the original clutch. There was nothing wrong with the clutch when we split the engine.
@chatis avatar
@chatis avatar
One other bit of information. When torqueing the flywheel we put the scooter in gear and held the axel. This did not work since the clutch slipped. Could this have caused the issue??
@christopher_55934 avatar
2007 Stella 225
2007 Stella 225
As others have said the clutch cover is pushing on the clutch basket, same as the lever pushing on the clutch basket center. The causes the plates to separate. Maybe the lever or one of it's parts are incorrectly installed.
@rowdyc avatar
@rowdyc avatar
What type of repairs were done that needed the cases split? Was anything done in the crank area? When you torqued the flywheel nut by putting the scooter in gear and holding the axle may have moved the crank. I don’t know but that is not a wise way to do it as found out. Sure it didn’t help as that’s force on gears, Christmas tree gears and clutch.
What you do know is that the clutch is now touching the cover. Either the clutch moved or the crank moved. Of course you can put a band aid on it with a clutch cover spacer but the real problem may pop up later. If you didn’t remove the clutch make sure the crank and main bearing are seated properly. Make sure flywheel nut is torqued.
Something moved or the clutch cover got narrower???
@xantufrog avatar
Moderibbit
Moderibbit
@xantufrog avatar
You torqued the flywheel using the clutch (or tried to)? You should get a flywheel holder - I'm not sure if you can torque (in the other sense of the word) the crank seating that way but remember that the clutch can only provide resistance to the flywheel via the crank web bearings
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
It sounds like a good way to twist your crank, but not likely the issue here
@108 avatar
V range 50s
@108 avatar
V range 50s
Long shot guess… But, sheared clutch woodruff key…
Maybe the clutch cover holding the clutch down is enough for the Kickstarter, but once the cover is loose, the clutch spins on its own…
@moto64 avatar
@moto64 avatar
Check to see if the clutch cable outer is seated inside the adjuster and not hung up on it.
@rowdyc avatar
@rowdyc avatar
Video shows motor not connected to frame
@moto64 avatar
@moto64 avatar
Sorry......
kinda jumped in there. Sounds like the clutch is slightly disengaging when the cover is tightened, If you just place the cover on the case , maybe without the screws, can you feel any contact with the pressure plate before the cover is seated ? You could put a blob of putty or wax or something on the plunger and then tighten the cover and see how much it gets squished.
@dsmith181 avatar
1965 Allstate, 1979 Rally 200
@dsmith181 avatar
I know it's been awhile but I'm dealing with exactly the same issue. We're you able to resolve this?
[ Time: 0.0108s ][ Queries: 3 (0.0044s) ][ live ][ 313 ][ ThingOne ]
