Piaggio MP3 300
Piaggio MP3 300
When rear tyre/wheel on outside is rubbing and when on stand with brake off, turn wheel it sticks part way
2012 Piaggio 300 LT Touring.
@pmatulew avatar
2009 MP3 400, 2004 Honda ST1300
@pmatulew avatar
New tire? Correct size? Properly seated on the bead? Missing spacer when wheel was reassembled?
Piaggio MP3 300
Piaggio MP3 300
Tyre not new. Why is wheel hard to turn back and easier to turn forward. May have to take to mechanic.
@maksor avatar
Gilera Fuoco 500ie
@maksor avatar
Gilera Fuoco 500ie
wrong size a 300 needs a 140/60/14
@pmatulew avatar
@pmatulew avatar
If the tire is not a new install, has it always been rubbing on the outside?
If it feels like something internal is not right, then yes it should probably be looked at by a competent mechanic before the problem escalates.
@fentonfred avatar
2009 Piaggio MP3 250
@fentonfred avatar
I had to adjust my parking brake for the same issue, it was catching the rim but only in certain positions - I assumed the rim was warped.
[ Time: 0.8695s ][ Queries: 3 (0.0023s) ][ live ][ 313 ][ ThingOne ]
