Vespa LX50
Vespa LX50
Hello
i have a 2016 Vespa Primavera 50cc 4v 4t 4k km
And i have a problem i just cant figure out so i am hoping you can help
ok when First start the scooter starts up Perfectly . But
after 30 sec it like runs out of fuel and then its a little hard to start up
but after its running and warm it runs perfectly
Now i tell you whats been Done
New Carburetor
Nen intake manafold
new fuel lines
New fuel Vacuum
and there are no fuel leaks on the ground
but its like the fuel lines run dry and the only fuel when i first start is must be in the carb bowl but i don't understand why . any IDEAS ???
Robbie44 wrote:
Hello
New Carburetor
Nen intake manafold
new fuel lines
New fuel Vacuum
try this :
when the engine manifest the issue, you have to understand if fuel line works, take out the fuel line from carburetor and try to start the engine, look if fuel spill. stop.
if yes, is an electric problem.
spark ? ignition coiil ?
first try to check if the cord between ignition coil and spark plug is firm.
same if the cord is firm in the spark plug.
spark : is it correctly in ?
take a look of the spark electrodes
control that all the wire and ground (-) wires are firmly in position in the engine area.
all items are fallible, brand new too.
2020 primavera 150
2020 primavera 150
Try it with the gas cap off
2020 primavera 150
2020 primavera 150
Did you happen to put a inline fuel filter on this as I put one on mine when I was having the same type of problems and had to take it back off as it would no keep running?
correct, if works the vent hose is blocked
[ Time: 0.0096s ][ Queries: 3 (0.0015s) ][ live ][ 313 ][ ThingOne ]
