@swiss1939 avatar
@swiss1939 avatar
I'm searching for the part# 662 which is the electrical connector tabs for coils to ground to the coil mounting screw. I can't seem to find them anywhere and I've searching the usual electrical parts sites for similar ring terminals with no luck.
I can just resort to the standard straight right terminal, and I most likely will but it would be nice to have a side clamped tab instead of a straight mounted ring. Not sure if straight mounting rings will leave enough length of wire to mount it to screw on an angle.
I'm sure I could probably also fab one up from some sheet metal or something although I'm being lazy here and looking for purpose built options.
My fallback is this ring terminal from mcmaster:
https://www.mcmaster.com/8429T16/
But I figured someone on here might know where these are.
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
They’re called flag ring terminals. McMaster has them.
@swiss1939 avatar
@swiss1939 avatar
Awesome. Thanks Socal! Exactly what I am looking for.
[ Time: 0.0123s ][ Queries: 4 (0.0058s) ][ live ][ 313 ][ ThingOne ]
