Does anyone know if the new cylinders have different porting to the 2013/2016 kits (MHR and Sport), or is the separate/steel exhaust stub the only difference?
@108 avatar
V range 50s
@108 avatar
V range 50s
What is this mate???
Oh no… I found it on SIP and scooter center…
Why’d they have to go and do this, just when real life work was picking up…
But looks like nothing much has changed… the exhaust flange seems more for racers and the ability to swap it out if needed.
Was hoping they went even more aggressive on the port timings
Jet Eye Master
Jet Eye Master
You we're the first to notice. All info says its the same timing. Hopefully will be a while before I ruin my new MHR kit and need one.
Using an O ring exhaust with springs, I can't see how this is any better. Now it has another point where it can leak or fall off. Although will be easier to tune the exhaust Port, always a silver lining somewhere.
Interestingly, the SCK video is referring to a keystone piston ring and the need to fit it the correct way round, which I thought we'd established was no longer used, since Malossi started to use the Vertex piston. Can anyone confirm one way or the other?
@safis avatar
@safis avatar
They never ditched the keystone type ring, even with the Vertex pistons…
Thanks SaFiS, I just bought the MRP CNC head for my MHR, so I'll check the ring orientation when I when the cylinder and fit the head this weekend
[ Time: 0.0113s ][ Queries: 5 (0.0033s) ][ live ][ 313 ][ ThingOne ]
