2009 250 GTS Super
2009 250 GTS Super
I've got a GTV 300 that hasn't been ridden in 3 years.
Is the oil still good or should I put in a new set of oil just to start fresh?
Hasn't been that many miles
Thank you
@grouper avatar
2020 GTS 300 hpe Touring
@grouper avatar
The oil should be changed yearly.
@kaukari avatar
GTS 300 ABS, 2018
@kaukari avatar
GTS 300 ABS, 2018
Oil is probably one of your smallest problems if it has not been ridden for 3 years. I would change fresh oils anyway. Cheap and easy.
@dooglas avatar
@dooglas avatar
You have also missed the regular change interval for coolant and brake fluid.
2022 Honda PCX 150A, 2018 GTS300 [sold] & 2015 GTS300 Super [sold]
+1. And yes, without a doubt change the engine oil and filter (and possibly the rear hub oil), too.
@2wheelsdan avatar
GTS300 supertech
@2wheelsdan avatar
GTS300 supertech
We're talking about 1.3 liters of oil, how can this even be a question.
@corn avatar
GTS300 Super
@corn avatar
GTS300 Super
When in doubt, change it out...
better respect engine service timeline.
ps, change brake fluid too
@attila avatar
@attila avatar
+2!
2009 250 GTS Super
2009 250 GTS Super
Roger that.
@baba12 avatar
2018 Vespa 300 GTS Touring
@baba12 avatar
Given the cost of doing an oil change yourself, you shouldn't hesitate to change it. Changing oil twice a year if you do it yourself keeps your machine running smooth.
Change oil, change coolant, check battery and make sure air pressure is right in the tires.
[ Time: 0.0103s ][ Queries: 3 (0.0043s) ][ live ][ 313 ][ ThingOne ]
