hi all
I've got an issue with my 2014 Vespa Primavera 150cc scooter. I hadn't used it for a while and when I tried to start it, it wouldn't start. i removed the battery and recharged it. The battery was purchased last year.
After the battery was recharged, it still wouldn't start. The headlamp does not turn however all the other lights and horn seem to work fine.
I've uploaded a vid of what the panel shows when I try to start the engine here
Any idea what the issue is?
thanks in advance.
@rottekatz avatar
Primavera 150
@rottekatz avatar
Primavera 150
Take the battery to Wal Mart or any parts store and have it checked. Most will do this at no charge, ask first. If the battery is not good, you should purchase the replacement there.
yep, did that before, they said the battery was fine.
check the headlight
2020 primavera 150
2020 primavera 150
Check kill switch
2020 primavera 150
2020 primavera 150
This sounds more like a bad battery
[ Time: 0.0148s ][ Queries: 3 (0.0044s) ][ live ][ 313 ][ ThingOne ]
