@pheasant_plucker avatar
bare metal cafe racer
Failed my warrant of fitness because the Siem headlamp was pointing too high. The guy asked me, “are you planning to shoot possums?” I checked it and it was only 3deg up (not really treetops…) I knew it was out - the guy who did my first certification turned a blind eye. When back to the same place but got a different guy. Needed to make it functional anyway…
So did some maths (soh car toa) and figured I needed to shift the bottom of the headlamp back 10-12mm to drop the angle ~6deg. Meant to be 3-3.5deg down for a “symmetrical” beam.
Prized the Siem apart…
Cut a wedge of 1.5mm rubber to tilt the front - it sits on the tabs.
And made a wire ‘clip’ that holds the lamp in tightly at the bottom. The top is held in by the original tabs.
One of the headset threads for the headlamp was stripped. So found a plain M4 nut…
It would sit far too proud in the headset to fit the headlamp back on - so dremelled the headset to about 1mm to sink it as far as poss. Roughed it up, cleaned both surfaces with isoP, then stuck the nut in with JB weld…
Came out pretty well…
And definitely pointing down now. Actually might be too far down - but can adjust it by trimming the wedge. Will lift it at the testing station if I need.
@hibbert avatar
Vespa
@hibbert avatar
Vespa
wow great illumination of the instruments!
[ Time: 0.0083s ][ Queries: 4 (0.0021s) ][ live ][ 313 ][ ThingOne ]
