Vespa Primavera 50 2019
Today I was driving my Vespa Primavera 50 2019 when all of a sudden it turned off. I restarted it again without issues, but if I don't keep the gas pulled, the Vespa turns off again. Also, I noticed that as I pull the gas, acceleration is not steady. I checked the engine area and noticed that there were two loose hoses which do not appear to be vents. Before I take it to the dealer, do you think the loose hoses connect with each other or anything at all? Thanks.
2020 primavera 150
2020 primavera 150
The one that is discolored looks like it needs to be replaced ( 3/16 rubber works great) the other one should be directed down as a vent I believe
2020 primavera 150
2020 primavera 150
No the black rubber may not go down It looks like a vent is already in the down position .Also check the manifold for leaks (underside)
2020 primavera 150
2020 primavera 150
The black plastic filter with 2 clamps you can do away with and run new hose from fitting to fuel valve as that is what dealer told me and that is what I did
2020 primavera 150
2020 primavera 150
The black hose goes to a fitting on the valve cover
2020 primavera 150
2020 primavera 150
Under the coil
[ Time: 0.0088s ][ Queries: 4 (0.0032s) ][ live ][ 313 ][ ThingOne ]
