Lol Star 125
Lol Star 125
Have replaced my lml 125 2T 04 plate wiring loom because wiring was brittle needed to connect the starter motor relay wiring there are two larger wires a red and blue that fit on the right of the relay,then two smaller wires a brown and a pink/red on the left of the relay.Need to know which way around they fit on the relay, scratching my head at moment and need some help please Crying or Very sad emoticon
@safis avatar
@safis avatar
It doesn’t matter…
Lol Star 125
Lol Star 125
There must be a reason why two different colours if I connect anyway around no damage ? Should I just bite the bullet and go for it !!
@moto64 avatar
@moto64 avatar
The smaller set of prongs is a circuit that when completed , actuates the solenoid.
The other larger set are the starter circuit which is completed by the solenoid when the smaller circuit is completed.
It looks like the spades are different sizes for the two sets of wires so the circuits are clear and the position of the colored wires is not critical.
Lol Star 125
Lol Star 125
Thanks for that reply I will reconnect as instructed and look out for any SMOKE that's the trouble with me (a proper scaredy cat !!)
Lol Star 125
Lol Star 125
Have fitted the starter motor relay and took notice of what you said with ref to the large and smaller connections the only connection I am not sure about is a black does this earth the relay or go to negative on battery
Any help grateful(all this cos I did not image beforehand !!) Hi Jim
@christopher_55934 avatar
2007 Stella 225
2007 Stella 225
Earth, negative or ground should all be common. The negative wire from the battery should connect to the frame somewhere on your scooter. Without pictures, if you're talking about two smaller gauge wires for a relay one is positive when you press the start button the other is a ground. You can connect it to a good ground spot on the chassis.
This picture is basically what your trying to wire up.
https://www.swe-check.com.au/images/editorials/relay-wiring_example2.gif
[ Time: 0.0210s ][ Queries: 4 (0.0151s) ][ live ][ 313 ][ ThingOne ]
