@dazlleritsamodernworld avatar
sprint 150 / 244 qaun
Hi all
after some advice as electrics are not my thing, the engines been in a few months now with a new 12v loom fitted, i fitted also a 12v handle bar switch for the lights and everything is been working fine.Then thursday night all the bulbs blown, i then changed these and everything was working again on tick over and slight revs. i went out yesterday and everything has blown again. could someone point me in the right direction as to where the possible fault is?
thanks in advance.
If you are not running a battery, I suspect your voltage regulator is bad.
@chrisfromcle avatar
2019 Primavera 150, 2019 Honda Super Cub 125, 2017 Honda Metropolitan, 1965 Honda Super Cub 50 CA102
Just guessing but I would look at your voltage regulator.
Chris from CLE
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
As said above, your electrical system is producing more current at high revs than your bulbs can handle.
The fix is to either increase the wattage of the bulbs or regulate the voltage.
Could it be a bad earth as this is fasten behind my rectifier to the frame ?
i noticed last night the rectifier moved and was not solid. couldnt try bulbs as i have run out.
@waspmike avatar
@waspmike avatar
Lucas? Facepalm emoticon ROFL emoticon
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
Could definitely be bad earth.
@neil_edgar avatar
'81 50 special,'57 GS150 VS3,'59 152L2,'60 SII Li150
@neil_edgar avatar
Waspmike, only very early Douglas Vespas have any "Prince of darkness" electrical parts!
[ Time: 0.0081s ][ Queries: 3 (0.0015s) ][ live ][ 313 ][ ThingOne ]
