65 small frame and 64 large frame Allstate
Can an injected 20-20 carb ( the D version) be used without injection?
If so, are any mods required?
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
Yes, injected can be used on non-injected. Only mod required is the slide puller has to be changed to the kind that connects directly to the cable instead of to the oil pump.
@xantufrog avatar
Moderibbit
Moderibbit
@xantufrog avatar
Are you trying to disable autolube? Or just use an injected carb on an already non-injected bike?
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
if it's a formerly autolube bike, I like to fill the channel in the bottom of the carb box with RTV to avoid any air leak there where oil would have been flowing.
@scooterist avatar
@scooterist avatar
I think you also have to change the gasket between the carb and the rotary intake base, the gasket comes with a hole for the oil but since you are doing it the other way around I think you are going to be fine. I had to RTV mine because I also did the conversion.
You can plug the oil line if you want to as well.
Looking at an injected carb for a non-injected bike.
It's a 64 Allstate I'm converting to a VBB/VBC front end.
The piston and cylinder are seized beyond hope but I was able to salvage the crank and con rod without any damage.
Thinking of going with either the 57 or 61 oversized set from Mercato, but the 61 would probably need a 20-20 carb.
I've seen 20-20 D's for a reasonable price, hence the original question.
@gickspeed avatar
@gickspeed avatar
Money better spent would be to go to an uprated spring in the front end. Money saved can be spent on a Pinasco 177, 20.20 carb, decent new crank, and BOX exhaust.
You can thank me later. 😁
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
Gick you've got me thinking I should do that with my 2 port engine that I've got sitting about, maybe it should go in the vbb...
@gickspeed avatar
@gickspeed avatar
happy i get some guys thinking about better ways to spend $$$.
Not looking to create a 60 mph barn burner, just a backroads cruiser. Plus I really don't want to spend that kind of money on this bike.
@gickspeed avatar
@gickspeed avatar
cool. because you certainly will not create a 60 mph barn burner with that setup. just better ways too spend your money.
[ Time: 0.0191s ][ Queries: 4 (0.0108s) ][ live ][ 313 ][ ThingOne ]
