@dark avatar
GTV 300 - GTS 300
@dark avatar
GTV 300 - GTS 300
Is there a source for used modern Vespa parts?
Cannonball took it's toll on my 2012 GTS & I'm in search of a rear axle shaft & hub.
Also a front brake calliper
⚠️ Last edited by Dark on UTC; edited 1 time
@boraxman avatar
GTS250
@boraxman avatar
GTS250
I have found good used parts on Ebay
0:7 And counting
0:7 And counting
This bit?
0:7 And counting
0:7 And counting
I can't remember the provenance of this particular part, so I can't attest to whether it is suitable or not.
@dark avatar
GTV 300 - GTS 300
@dark avatar
GTV 300 - GTS 300
Yes, that's the part. The splines appear to look better than mine a better picture of the splines might help though.
@dark avatar
GTV 300 - GTS 300
@dark avatar
GTV 300 - GTS 300
I sent a seller there a message re a hub but haven't gotten a response.
0:7 And counting
0:7 And counting
Close up of splines:
@dark avatar
GTV 300 - GTS 300
@dark avatar
GTV 300 - GTS 300
for sure look better, pm sent
@dark avatar
GTV 300 - GTS 300
@dark avatar
GTV 300 - GTS 300
Axle has been sourced. THANK YOU Jess!!! Clap emoticon
I still need #7 in this picture & a front brake caliper
@greasy125 avatar
@greasy125 avatar
Let me dig around in my pile. I'm pretty sure I've got what you need.
@dark avatar
GTV 300 - GTS 300
@dark avatar
GTV 300 - GTS 300
Much appreciated!
AF1 racing often has a number of used parts available.
@willie_b avatar
@willie_b avatar
I should have a front brake caliper. Let me look
@dan_v avatar
gts 300
@dan_v avatar
gts 300
I have a caliper that I just replaced with new for my 2010 GTS. I replaced it because I had a pulsating brake, thought it was that one of the pots was stuck. About 4000 miles. Yours for shipping.
Met you briefly at the checkpoint in Vermontville - my wife and I had some granola bars and nuts for you. Say hi to Scott for us!
PM if you are interested.
@dark avatar
GTV 300 - GTS 300
@dark avatar
GTV 300 - GTS 300
PM sent & thank you again for the snacks that day in Vermontville, that was very kind of you and your wife & we really appreciated those snacks that day.
2007 Vespa 250 GTS
2007 Vespa 250 GTS
I am searching for a front shock. I'm told the shock with the word Escort on it and the number 599601 will make a nice improvement to the ride and remove the headshake.
Thanks in advance
Tony in Tn
PS: Please forgive the highjack
@dark avatar
GTV 300 - GTS 300
@dark avatar
GTV 300 - GTS 300
Looks like I've found a brake caliper, Thanks Dan V Clap emoticon
Down to searching for just a hub now, #7 in the picture above.
There is one on ebay but I'm hesitant because the seller won't return a msg asking for a picture of the splines in the hub.
@greasy125 avatar
@greasy125 avatar
Hang tight. Think I got you.
Dug up two out of the stash, but let me inspect and make sure one or the other is decent. You'll get the better of the two!
@dark avatar
GTV 300 - GTS 300
@dark avatar
GTV 300 - GTS 300
Great, thank you very much
@dark avatar
GTV 300 - GTS 300
@dark avatar
GTV 300 - GTS 300
Still looking for a Pre ABS hub for the GTS.
Aprilia Mojito 125
Aprilia Mojito 125
Looks like a hub of mp3
[ Time: 0.0130s ][ Queries: 4 (0.0021s) ][ live ][ 313 ][ ThingOne ]
